Guest
·I took my car to Le Luc circuit near St Raphael yesterday. It was a lot of fun. Apart for my tires. The S01s are gone, huge chunks have left them on the outside edges. This is the rear axle, with AYC. The AVS in the front look pretty bad, but that is because of all that understeer.
Anyway, my point was to tell you that my brake set up worked fine every time, very little fading, no warping. The only problem was to not brake too hard because it triggers the ABS every time. This really písses me off! With normal tires! On a dry track! What kind of BABS settings have they put on their Evos? Renault setup? Or is it Bosch Mercedes type ABS?
Sorry for that, had to let it out. But now I think I was not hard enough on the brakes, that I didnt brake hard enough and that if they didnt warp, it was because of me. On the other hand, the calipers are almost black now...
