1 - 16 of 16 Posts
Can anyone help please?
What are the spec of mr cams? is there much benefit of using them on a 6 with standard turbo?
Cheers Ed
Anyone?
What increases will i see over standard? car is currently standard motor 328bhp 314lb/ft
Ed
Anyone?
Ed
these cams will offer very little gain over the cams you have.a bit of a waste of time fitting in my opinion.your better off getting hks 272 or gsc s1s
Factory EVO
Advertised Duration - 260 deg Int / 256 deg Exh
Lift - 10.0mm Int / 9.5mm Exh
Lobe Centerlines - 109 deg Int /111 deg Exh
LSA - 110 deg
JDM EVO MR
Lobe Centerlines - 113 deg Int /112 deg Exh
LSA - 112.5 deg
i would say there worth it for a evo4. i put evo6 ones in mine and it felt alot more willing to rev specially at higher rpm.
1 - 16 of 16 Posts
