Well the car is almost there so its time to think ahead to the ecu.
I have a motec m4pro to fit and was wonderingwhat sensors are neccessary?
I was told i need water temp but can this not be taken off the existing 1.
Also air temp which is ok but i will require a 4bar map sensor as i want to run over 30 psi if possible, does anyone know where i can get 1 for a good price as they are bloody expensive.
Is there anything else i will need.
This ecu is the version that retains the standard 1 if that makes any difference.
I'm using a Kavlico 5 Bar Absolute bought fromOBR Motorsport
About 90 quid from memory and lets you run upto 4 bar boost. If you ask when you buy they also supply the cal values for the input to MoTeC (or I can copy mine for you)
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Lancer Register Forum
