Guest
·Hi All,
I'm having some more problems with my RSX, and am looking for some opinions.
My local dealer was convinced that my electrical gremlins were being caused by a duff battery, and duly replaced it under warranty. Unfortunately, the problems haven't gone away, and the dealer is now claiming that what I am seeing is normal.
So, what am I seeing, I hear you ask. Well, the biggest problem appears to centre around a massive voltage drop when a lot of electrical equipment is running. The simplest thing I can do to reproduce this is turn on the lights (not full beam), heated rear window and air conditioning. When you then turn on the fan (to activate the air. con.) all of the lighting in the car almost goes out, and the engine hiccups and nearly stalls. If you repeat the exercise with about 5000rpm (to discount the alternator not running to speed at low revs), then the exact same thing happens.
I'm pretty sure that this is not normal, as no other car I have ever had experiences this kind of problem.
I've discounted the battery, as it has now been properly load tested by another local garage. This leaves me thinking that either the alternator is not working correctly, or it's just not pushing out enough power.
I've also had some problems with front fog lamps, as they keep blowing 20A fuses. I've now left the fuse out until it gets looked at.
Another problem that's just occurred is a really weird clunking sound from the OSF suspension. It sounds exactly like my old Renault 19 16V did when it's CV joint was on the way out. It doesn't occur when turning, just when going over quite large bumps, e.g. speed bumps. The car has never done this before last Wednesday. Anyone got any clues as to what it might be?
Enough of my rambling. All opinions appreciated.
Andy.
Andy.
