1 - 10 of 10 Posts
i have a curious problem:
when i accelerate at 100% , pedal on the floor i got a quantity of power, but if i accelerate at the floor and rise the pedal about 10 ou 15 % (i don't know exactly), when the turbo is charges , the car seem to run with more power
why ??
ecu ralliart
boost 1.5/1.6
flter ralliart
full decat 65 mm
dump blitz
in full accelerate, i have a grey smoke behind me and only in this case
but car don't smoke the morning at start, don't eat oil, don't smoke blue or white, run very well
sorry for my french's english
MKS said:
english is better than my french m8 :)
sounds like a fuelnig problem.. maybe an uprated fuel pump would help.
Yep, better than my French too :)
While you are right, it sounds like a fuelling problem, it almost sounds like he getting too much fuel at WOT.
Do you have a pressure regulator and what is it set to?
Also, did you realise that at 1.6 bar boost, the Ralliart ECU just opens the injectors wide open? They are only really 'mapped' to 1.5 bar.
thanks for your interest
for the fuel pomp 255 l/h , i'm not sure i got one (second hand car), how can i verify that ?
for the regulator it looks like from mitsubishi
that's why i 'm surprised to see smoke grey at this boot level
plugs have got a nice colour
at 1.7 of boost i got this smoke grey too
have you got a picture of a fuel regulator not oem, put on a car ??
for the boost , i can put 1.4 stab/1.5 peak with no problem and i will
Certainly sounds like its overfuelling could be something as simple as a boost leak, slightly loose boost pipe or dump valve leaking?
Have you tried turning the boost down alittle to see if it makes a difference?
Discussion Starter · #7 · (Edited)
**I'll bet it is a timing/detonation problem...**
explain please ??
dangerous that !!!
detonation give grey smoke ??
sorry i'm french: when you say "overfueling " you said too much fuel ??
"he getting too much fuel at WOT" : what do you mean ?
explain please ??
dangerous that !!!
overfuellin = to much fuel
WOT = wide open throttle/ 100% throttle
the ralliart ecu is only able to run 1.5 bar, i wouldnt run anymore than that unless you get a new ecu
Alex
Papagogo,
The best thing to do initially is to get you car to somewhere that can check the lambda value of your exhaust gases under full throttle. This will tell you if you are putting too much fuel into the engine which will cause you to lose power like you are describing.
Andy
1 - 10 of 10 Posts
