1 - 10 of 10 Posts
· Registered
Hi all
Is it possible to fit Magnex downpipe/de-cat, Blitz Nur Spec and an induction kit first, then uprate the fuel pump (walboro) on Tuesday and then (date to be arranged) get Mr MAD to fit the Autronics/fuel reg? I think what I'm trying to say is are there any potential problems fitting all the other bits before getting the ECU bit done :confused: Phew!!! :blush: Cheers.
Justin
· Registered
Evo-Jase said:
Hi all
Justin
thats what majority do bud get the exhaust, decat and induction fitted first
and good choicem mark is the man :) :coolsm:
· Premium Member
Only problem I can think of is after you have fitted the Magnex downpipe/de-cat, Blitz Nur Spec and an induction kit you might find that your boost has crept up sufficiently to introduce fuel cuts when on WOT.
Appart from that no problem :)
· Registered
true, brian u had that prob didnt u i mind :) u or john
if u do get that problem justin if u dont have a boost controller u can get your tuner to lower the boost by adjusting the wastegate acuator, make sure he uses a boost gauge too :D u need to test it afterwards
· Premium Member
Mine never hit fuel cut on the standard ECU with a free flow exhaust/panel filter. Some cars are affected more than others, depends how the boost is set when it leaves the factory (they are not all set the same)
1 - 10 of 10 Posts
