41 - 46 of 46 Posts
Discussion Starter · #41 ·
Stud .... no problem on the pads :D
Springs... mmmm... are you sure you shorter ones are softer, and not just progressive? Standard springs are linear, so stiff all the time :)D) where as the lowered ones are progressive - soft at first, then stiffer than standard - so you get initial roll, but it firms up...
I would leave the set on that make it handle the best - lower ride height is usually better, even with progressive springs.
Discussion Starter · #43 ·
Well I've finally succumbed to my first MLR track day having had my booking confirmed by Darin.
Is anyone going down the M5 that would like to meet up en-route?
I'm actually doing Bedford on the Monday so that will be two track days in the same week.
Nearly as bad as Blade :D:D:D
Discussion Starter · #45 ·
I have a hundred or so pictures of the Castle Combe action from this afternoon.
MSN will only allow me to post 1.7MB of pictures and even when I reduce the size of the original, it is far too small.
Can anyone point me in the right direction where I can post these pictures for others to view.
41 - 46 of 46 Posts
