Geek Mapped
gauges
will they fit in the gap below the stereo on a 6?
Oh yes my freind, fit a treat!
I have some of these and they look the dogs dangly bits.
You have to squeeze them in there as the bracket is slightly too long but they fit ok, you need to drill new fixing holes in the bracket, then just put some washers behind the bracket to tilt it correctly with the rest of the console.
Hope this helps!
3gan.
Hope this helps!
3gan.
most def helps cheers dude! :D
gauges.
on an 8 remove inner wing lining,about 1/2 hr,run vacuum hose through large grommet where loom goes to fuse box,you need vacuum pipe,main dealer wants 26.00 and t piece 6.00.ebay 9.00 for 2.5m with t,volts live of stereo ign feed and black to earth,oil temp sender into oil filter housing,you need an adaptor,6.00 from bsr,i have one and temp sender from ebay 10.00,calibrate oil temp with hot water before fitting,small screw on back of gauge,dial into 100.c.main dealer want 18.00 for sender but as gauges are paired from factory might not work as i found out.hope this helps,took about 3hrs in all,the only info i found confusing was where to fit vacuum hose,didnt want to touch on the fuelling side so came off the dump valve.cheers murf.
