61 - 80 of 99 Posts
Discussion Starter · #62 ·
I gave up trying to finish my car in time for the event. When I was making the exhaust system I felt like the time limit started to effect the quality of the work I did. So I decided to stop because its not fun to build something that your not happy with even if it works. I have also decided to rebuild the fuel system some more, with a catchtank, bosch pumps etc. More info on this next week.
Some photos with the engine in place.
I did help a friend finish his Nissan s14 in time for the event. I have built his rollcage, exhaust manifold, head work and some more work. We finished the car at midnight 25/7 so he could run the kinnekulle Ring event on the 26 :)
Here some photos of it:
Discussion Starter · #63 ·
Have done som more work on the car.
New fuelsystem is done, 255 walbro as lift pump to a swirlpot, dual bosch pumps from swirlpot to engine. New fuellines an8 feed and an6 return.
I had a new ignation coil system ready(4 vag coils) but then I found out that my PNP autronic cant adjust dwell time. And the coils are 2,5ms, so now I have to get new coils again :(
I have also started to assemble the car, finished up the harnesses etc in the car so I could start putting the dash and seats in. Then I fitted the doors, front fenders and test fitted the front spoiler. I will need to do some cutting in the front to make room for the IC piping. Then it will get some new paint :)
Hi
I gave up trying to finish my car in time for the event. When I was making the exhaust system I felt like the time limit started to effect the quality of the work I did. So I decided to stop because its not fun to build something that your not happy with even if it works. [/IMG]
Couldn't agree more as I have done that " once ".... Total fasle economy :smthumbdo
Wow, nearly there ....
Loving your thread mate, appears you have aquired ALL the skills you need :smthumbup
Sure wish I could get things done as fast as you ....
Discussion Starter · #66 ·
Hi
Hi,
It feels so much better when you know that it is as good as you can do it. Im not saying that im trying to make it perfect but I want it to be as good as I can make it.
Yes, its starting to look like a car again, will be nice to try to start it soon:)
Thanks! Still learning :)
Discussion Starter · #68 ·
Radiator, innerfenders, ac fan to cool the radiator and some other parts is now in place.
I finished up the welding on the exhaust system, just need one more bracket and to build the pipe from the wastegate to the exhaust. I have started with how the wg pipe will go into the exhaust. I hope to have the complete dp done during next weekend.
Here some photos!
And a bonus photo of my faithful friend, imported from the streets of Irland :smthumbup
Brilliant thread mate, a pleasure to read :smthumbup
Discussion Starter · #75 ·
Thanks Andy!
I dident get the piping for the wg pipe before the weekend so today I made a new cold ic pipe. I sold the other one to a IV driver a few month ago. Dont mind the diffrent colour hoses, I will get new once as soon as the car is done :)
Fuel catch tank in the trunk.
Discussion Starter · #76 ·
Made some progress this weekend. First I bought a used Ralliart front and a torsen center diff, I also got a few driveshafts, wheel bearings etc. So now I have some spare parts in case of failure :)
I finished the downpipe and the exhaust and dp is fitted to the car.
Then I cut and welded a 4" pipe for the airfilter to turbo.
I have bolted on the brakes, brakelines, oil cooler and some other parts. I measured how long oil cooler lines I need so I can get this made during the week.
I have done the wiring for the fuelpumps in the trunk. I also Filled up the transmission with redline oil.
I hope to get the fuel injectors, ignition coils etc soon because its getting closer to start up :)
The pump I use to fill transmission oil. My dad had a Gulf gas station back in the 70th.
Discussion Starter · #78 ·
I got tired of waiting for the bolt on TB from USA so I decided to build my own intake plenum. And use wich ever TB I can get my hand on :)
Work started, will post more pictures once its done.
Hey ....
Just loving it :smthumbup
Your a man of many tallents of which I wish I had !
CheeRS .... Del
61 - 80 of 99 Posts
