Evo 8 MR FQ320
GH – CT9A SJGFZ
CT9A-030-3948
Silver
Had this car for a few years now and am extremely reluctant to sell it as I absolutely love it, will 100% miss it once it's gone but I have too many projects on the go and this is one that has to be cut...
I had started to refurb the subframe and front end which I have lots of pictures of.
Drives so good, and pulls well all the way through the box, due to the twin plate and flywheel the clutch can feel a little heavy but I have had no issues.
Plenty of time, money, and TLC spent on the car as you will be below. I have a folder with most of the receipts but some from the previous owner are missing.
Had the Map checked by CPP in Sandbach but don't have any dyno printouts, they confirmed the Map is excellent.
Anyone who has driven an Evo will surely appreciate this car not driven another car like it.
Geo was previously done by Suspension secrets but I have changed suspension, brakes and subframe etc around since then but still have that unbelievable cornering and weight balance as before.
Current MOT till 27th March 2023
I have included a few before and afters of parts that have been restored. 90% of the front bolts have been swapped out for new. I also primed some of the underside and inner arches for now until I could get around to restoring the underside, all areas that have been done were taken back to bare metal first which I do have some pictures of.
Any questions please contact me.
Open to reasonable offers.
All inspections are welcome.
Test drives are possible just bring proof of insurance, don't just tip up and expect me to let you have a go.
Engine/ Drivetrain
  • 10.5T single flap housing
  • Upgraded Cams
  • 13 row oil cooler
  • Twin boost solenoid
  • Optimization and reinforcement of the oil channels in the pistons
  • Upgraded 5-ply head gasket
  • Added tension in piston rings
  • V shaped grooves in 2nd land of pistons
  • Reduced weight S-AYC diff (Alu casting)
  • Higher strength hypoid gears
  • HKS panel air filter
  • HKS hard pipe kit
  • SFS boost hoses with stainless Murry clamps
  • Uprated 255 fuel pump
  • HEL uprated oil cooler hoses
  • 3” turbo back Scorpion/TSL exhaust with Russ fellows silenced decat
  • Remapped to 385bhp by Extreme motorsport Whitburn
  • Exedy twin plate HD clutch assembly with flywheel
Brakes and suspension
  • Hel brake lines
  • Standard Bilstein shocks with upgraded Eibach lowering springs
Exterior
  • Ralliart carbon front splitter
Additional
  • MR Seats and door cards
  • Carbon effect dash
  • Team dynamic alloys 17” alloys
  • Subframe recondition and powder coated
  • Recondition CV drive shafts and painted
  • Painted lower front arms
  • New ABS sensors front
Services
DateMileage
05/08/0919013
04/11/0921527
26/11/1027238
07/04/1128040
09/12/1132044
21/06/1233087
08/11/1234102
02/10/1335200
07/02/1437113
16/10/1437304
27/04/1537578
03/05/1837581 (timing belts)
03/05/1837581
01/10/1838600
03/05/1938749
01/12/2040836
04/12/2040851
12/02/2141358 (CPP)
Works carried out and items purchased.
DateItems or worksCost
28/03/22Front OS chassis repair55
01/10/21Track/Tie rod ends
Front lower arm assy
Exhaust hanger assy
Powerflex rear engine mount
Powerflex front lower engine mount
Oil seal T/F case
Oil seal driveshaft to gearbox
02/11/21Hose, P/S oil return
Clip P/S oil line
45.56
27/10/21Various bolts and washers
Bushes
28/01/22Various bolts and washers35.30
20/01/22Front hub bearingx2104.99
09/08/21Brake bleed and new fluids55
20/01/21Various oils150.38
26/10/20Various oils63.66
03/08/21Various bolts and washers131.94
12/02/21Oil replacements
Check vehicle
Check map
121.78
21/10/21Various bolts36.15
25/10/21Various oils129.28
05/12/17Rad
Exhaust manifold shield
Gaskets
334
04/12/17Rad assy
ABS clips
1167.20
25/01/18SFS replacement hose kit
ABS clips
62.91
06/04/18Various brake and ABS items51.60
19/04/18Front brake dust covers57.14
25/05/18Badges55.52
15/04/19Front wheel bearing assy100
19/10/17Bilstein front and rear shocks with springs
Oil sump
Hel oil cooler lines
1122
30/07/09Oil filter
Spark plugs
front brake pads
182.39
10/01/10Blow off valve161.56
09/04/11Exedy clutch and fit1523.94
15/02/10255 fuel pump99.88
16/10/18Alternator284.38
16/10/18ContiTech drive belt15.27
05/11/12Hub kit150
20/10/17Oil filter
Gasket
17.41
