ENGINE
Cylinder head and amp; gasket,valves, springs, guides,camshaft and amp; bearings,cam followers,hydraulic lifters,push rods and rocker gear,timing gears, timing chains and amp; tensioners, pistons and piston rings,cylinder liners and seals, connecting rods and small end bearings,gudgeon pins, crankshaft and bearings,oil pump and oil pump drive,distributor driveshaft,flywheel and starter motor ring gear, inlet and exhaust manifolds.(excluding oil leaks)
TRANSMISSION
Internal componets comprising crown wheel and Pinion,Diff gears and bearings,halfshaft and bearings,driveshafts,bearings and cv joints,propshaft ujs and central bearing,hubs and wheel bearings
COOLING SYSTEM
Internal failure of water pump,visous coupling,radiator and expansion tank,oil cooler and heating matrix,
Excluding damage caused by frost or lack of antifreeze,clogging,sedimentation,hoses,clips or pipes.
ELECTRICAL SYSTEM
internal failure of alternator and starter motor,
Claims limit is £2500 per claim
*Mechanical or electrical failure-means the sudden unforeseen failure of covered componets arising from any permanent mechanical or electrical defect,causing sudden stoppage of its function,necessitating immediate repair or replacement
*normal deterioration of componets arising solely as a result of wear and tear is not covered.
Also covered in europe for 60 days per year and includes breakdown service.
Cost Upto 450 for 12 mths
Upto 750 for 24 mths
Upto 1150 for 36 mths
Cars must be under 6 years and 60,000 miles
Tony
