Firstly a big thank you to David @ RSpec for lending me one of his Oil/Water temp senders, which I've cooked ;)
With a bit of testing and the use of the oven :eek: I have a solution using the RSpec sensor with a 220 Ω resistor connected in series. It is a compromise and the resistor was chosen to give "safe" readings up to 125 °C, over that is. . . . expensive
Actual values obtained are (+/- 5%)
Gauge Temp - Actual Temp
80 . . . . . . . . . . 50
90 . . . . . . . . . . 67
100 . . . . . . . . . 79
110 . . . . . . . . . 94
120 . . . . . . . . . 112
125 . . . . . . . . . 125
130 . . . . . . . . . 150
The sensor used is this, note that it has a 1/8in NPT thread and could be mounted in a sandwich plate, oil pump body (with a thread reducer) or a modified sump plug
Resistors will be available from RSpec when I send some :)
HTH
Grant
Testing pics :D
for oil temp and aftermarket sensor you can just adjust the potentiometer on the back of the gauge.......easy:smthumbup
Well done Grant, going by how many people needed these they wiil be quite popular.
