1 - 20 of 41 Posts
hi all im in need of some help i was driving my 5 home today after cruising at around 35 i decided to plant the loud pedal almost instantly the car devolped a missfire and didnt stop i managed to poodle home which was only 3-4 minutes away still the car was missing i parked up and keyed off an re-started and its still missing constantly on idle and when thottle applied ive checked the plugs which are black at the base but beige on the electrode all pretty much looked equal any help whould be apprieciated ive checked the search and i cant find anything like this.
i recentley had the car mapped but it has been running sweet for the last 2 weeks untill now
also there is no blue balck white smoke out the exhaust
regards
dave
just checked that looks as good as it could my engine light hasnt come on and my coolant temps seem stable
dave
Get the sensors outputs checked to start with. There a a few problems with flashing the V and VI using Ecuflash, was it done with this or EcuTek?
it was ecu-flash who mapped it www.ecuflash.co.uk it wasnt the ecutech
as for the sensors i wouldnt have a clue what to do with them do you think its fuel related then.
when it happend it almost felt like it bogged down couple of small bangs then miss
dave
Have you checked all the ic pipes to make sure they have not popped off? Sounds like a scooby when they do including tick over.
grayw its not got a uprated fuel pump im running about 18psi no other mods
gray what are the problems with the map and can i resolve this if this turns out to be the case
ant1 thats what it sounds like a bloody scooby but with as much go as a donkey i need to get under it and have a look we did disconect the turbo feed today but i checked that and it was fine ill double check
dave
But did you check either side of the intercooler? Sometimes when you are on full boost the pipe pops off under pressure. Usually the right hand side. Look down inside the bay to the right and wobble the pipe. If it's loose it's off.
i will check thoughs tomorow i didnt even hit full boost mabe 10psi but i suppose it could still come off sod it im off to check it now
dave
right all the hoses are as they should be i dont want to start her tonite its a bit to late but they all seem nice and tight im starting to feer that its something expensive would the ecu record this type of fault even if the engine light hasnt come on i really dont no what to do
dave
It could be as simple a a ****ed coil pack fella so don't panic :smthumbup
Are there any decent Evo specialist around your way?
Normally you get a CEL for major fault, I'd still be looking for pipe splits to Start with.
dave
Discussion Starter · #18 ·
can i check the coils even though each 1 controls 2 cylinders like you would on a regular 4 pot 4 pencil coil set up.
i will check every hose tomorow and the coils if i can !!
i know of know one that is trustworthy in my area to work on evos unless anyone else does im in leighton buzzard
cheers for the help guys
dave
dave
pull a lead off see if the engine misfire changes, one by one check this, if the note, speed misfire does not alter on one cylinder only then this cylinder is your culprit,
if you find this, swap plugs around first see if misfire changes cylinder, then swap leads, see if misfire changes cylinder, very simple process of illimination.
if pulling leads etc changes note,speed,misfire, on all cylinders then your problem lies elsewhere
as gray says, check all pipework first to illiminate these,
if you are not mechanically, electrical diagnosis minded then as suggested take it to a reputable specialist.
hope this helps
Discussion Starter · #20 ·
im not bad on the spanners fault finding is not my strong point im gona look at the coils and pipes this morning ive got some spare plugs im gonna put them in a do some coil checking.
is there anywhere good in herts beds or bucks that i could recover my car to
cheers
dave
1 - 20 of 41 Posts
