1 - 8 of 8 Posts
Discussion Starter #1
anyone know how I would go about mapping this... all I need to know is where to get the software :D
Thanks in advance peeps
I think its premapped m8 like the Ralliart ECU (slightly more 'hardcore' map) so its not really re-programmable. You could probably get it Ecuteked but there is not really much point if you were doing that then you may as well map a std ECU and sell the Mines. :)
Discussion Starter #3
ahhhh haaaa cool, cheers for that fella..... so if it a little more hardcore I can handle that (not sure if the engine will like it much) but that's ok a rebuild never hurt anyone :D
So the mines will take in to account all the fueling etc, yes ? ?
Yep should do, although you will need an uprated fuel pump if you are going to increase the boost. Plus once you do it is always worth checking the fueling anyway just to be on the safe side :)
well i am running 1.5bars of boost and the limit is not 1.6 but 1.8 bars on mines.Btw does ne1 know where can i get it tunned??
1 - 8 of 8 Posts
