1 - 3 of 3 Posts
Lads i'm looking at buying a second car for parts. Looked at a cleanish E2 today with a crank problem which is going for very little money. Anyway it has a Mines VX-ROM ECU in it, what will this ECU do for my E3? it's a plug and play unit. Anybody know anything about these ECUs?
Paul,
The Mines Ecu's are pre-programmed in japan to suit spec of car when ecu is purchased, if the cars its on is the one it was bought for then whatever mods it has you can have etc....usually very similar to the Gizzmo chips etc. Is this the car you mentioned in my g/box thread ? if so sounds interesting :)
HTH
Ian
as Ian has said.....very similar to 'gizzmo' chips but more expensive
+ believe that the fuel/ignition curves mapped on the Mines will give a bit more torque and come on boost earlier than the gizzmo
1 - 3 of 3 Posts
