1 - 5 of 5 Posts
I am looking at replacing the Hypoid gear oil in my diff. I want to use Millers, but am bit lost on what one to use. Can anyone out there recommend which Millers to use.
Also looking to change the gearbox oil in our 8! Looking to use millers but as above unsure of which type? I know it's 75/90 but is it the CRX or TRX??
Ross:smthumbup
I used the CRX throughout.....rear diff, transfer box and transmission :smthumbup
Just another point with regards to using Millers. I had an 18K service @ Mitsi's a while ago and they put Castrol oil in my gear box. After the service I drove it home and the gear changes were bad. It was very hard to get into gear and it crunched alot. Not impressed. I had my gear box filled with Millers recently, and it has made such an amazing transformation to the gear changes. Its now smooth with no crutch. It is easier to get into reverse now. Very impressed with the results. I will definalty be using Millers again.
1 - 5 of 5 Posts
