Odd query really... Is there such thing as a method (or calculation) to work out how long a battery will remain charged for?
So if I know the total charged AMPs and Voltage, and I know the constant pull on the battery (AMPs) whilst it's not charging, can I work out the time before the battery is completely discharged?
Thanks,
Luke
yes
The formula for converting Amps to Watts is : Amps = Watts / Volts
To work out the total number of amp hours you divide by the voltage (12v) total watts /12 volts = amp hours.
You need the A-h rating for the battery and then it's a *relatively* simple task of just taking the amp draw from the battery and dividing the A-h by the draw to give you an approximate life.
However, if you're discharging the battery quickly then the A-h rating becomes less than the stated rating so you need to put in a fiddle factor to the power draw.
Then... you note that it's not a good idea to discharge the battery fully and you should still leave around 20% of it's charge in there to be able to recharge it properly and you get the following:
Time to discharge = rated capacity (A-h) / (current draw ^ 1.1) * 0.8
As an example.... if you have a Halfords HBO54 battery on your car then it's rated capacity is 45 A-h
If you have a current draw of 0.5 A then it will last
45 / (0.5^1.1) * 0.8 = 77 hours or just over 3 days.
Hope that helps
Andy
