1 - 2 of 2 Posts
MLR Oldie
Meaco DD8L junior dehumidifier. It's brand new and still in the box but it has a crack in the water collection tank. This doesn't matter if you operate it with a permanent drain (i.e. connect up the hose that's supplied with it and allow the water to drain away continuously under a door or down a drain etc) .
It has various settings, you can select high or low so it controls the humidity and turns on/off automatically, you can set it on a timer or you can use it to dry clothes by using the laundry setting.
I tested this and it works perfectly when used with the hose. A new water tank can be bought from Meaco for £24 if you decided you want one.
Cost £160 new. I'm looking for £90 for it.
I would prefer not to post it in case it gets damaged.
Located in central Scotland
Contact me via PM.(email - [email protected])
Pictures to follow.b
1 - 2 of 2 Posts
