1 - 8 of 8 Posts
Discussion Starter #1
Hey
Never purchased brakes since ive had the car but they now heavily judder an shake car when braking from high speeds!!!
Is this Disc or pads???? been quoted £1100 for the lot so only wana replace what i need!!!
Also when stationary if i squeeze brake pedal hard, a squeaky noise comes from the caliper!!
Any ideas guys?? normally have service with RalliArt/Extreme but dont fancy there bill on this one! lol!
Thanks :p
If it all needs replacing I would get std discs, some goodridge braided hoses and some Ferrodo DS2500 pads.
when you say squeeky noise from caliper is it more of a creak???
i ask cos mine did this recently........and it turned out the pistons were beginning to seize up :eek:
i pulled the rubbers back and sprayed in some grease and worked them in and out and the noise went away.....
Discussion Starter #4
Yeh thats it!! more of a creak! scared to deat RalliArt will say i need new caliper. i shall do that then, i presume it simple enough?? im no brake specialist! lol!
Cheerz Rich!
As for the discs an pads i dont know what needs replacing just that they judder! spose im gona ave to ask mechanic to take quick look!
:coolsm:
You can pick up a pair of OE discs for around £100 and the pads are no more than £150.
Then you just need a mechanic to fit them - or check the guide in the Articles section. I had never done anything on brakes before and I managed to do them no problem.
The caliper piston problem is again easy to fix, as you'll be taking the caliper off when fitting the discs anyway.
Discussion Starter #6
cheerz mate,
those prices sound abit more appealing! lol! presume there up 2 scratch on performance! will give them ago!
yeh will try fit them meself cant be that hard!
I've had exactly the same problem with my 5. I changed discs and pads and the problem has gone. The creak on the caliper also went away.
Mine are now squealling really bad and it's driving me mad!
They are the original parts, but just not sold through Mitsubishi. As for the pads, they are better than the originals. Try Ferodo DS2500's or EBC Red Stuff Ceramic.
Contact "stockcar" on this forum. He sold me my discs and they're great.
1 - 8 of 8 Posts
