Many Various Parts etc
4335 Views 57 Replies 21 Participants Last post by  Sider
All prices are collected from Leeds, West Yorkshire. Make me an offer.
Block cradle
Flywheel
Standard short engine, used but good
Complete head with cams, Mivec pulleys, some pipes and thermostat housing etc
Trigger wheel, front pulley, starter motor, cam cover, timing chain case
Oil pump, alternator, power steering and air con pumps, sump, various pipes and brackets
Standard exhaust manifold, standard turbo
In theory most of the parts, above, to build a complete engine with some ancillaries etc. Ideally sell as a job lot £1850, will entertain parts if enough interest.
Long engine, complete with most outer parts, suit a rebuild project (crate engine) £1800
Used Cosworth parts, crank, ISF polished and cryogenic treated, complete ported cylinder head, con. rods and camshafts £SOLD
Cosworth fuel injector rail £SOLD
ETS 4" bar core intercooler £SOLD
Koyo radiator (water) KV032037R £140
Carbon propshaft (suit GSR, not RS) £SOLD
Complete set Ohlins DFV c/w top mounts etc £SOLD
Complete set standard used Bilstein suspension with Tein lowering springs (will separate)
Pair Exe-tc adjustable top mounts (front) £50
Ross Sport swirl tank c/w Bosch 044 fuel pump etc (good for 600bhp) £220
Set of 4 ID 1000 fuel injectors £SOLD
3" air inlet pipe c/w maf housing and cone air filter £SOLD
AP Racing brake set front and rear (discs cryogenic treated) with XP10 pads, 2 spare front discs and 1 new disc (cryogenic treated) £SOLD
Full Milltek de-cat. exhaust with 5" slash cut outlets £SOLD
Powerflex 10Z75 front wishbone front bushes BNIB £12
Blox roll stopper BNIB £50
Mishimoto additional oil cooler (MMOC-EVO-08) BNIB £SOLD
Timing chain (Mitsubishi MN183896) cryogenic treated BNIB
Oil chain (Mitsubishi 1140A073) cryogenic treated BNIB £SOLD (for the pair)
K-MAC full race adjustable camber mountings BNIB £180
HKS Super Hybrid air filter BNIB £SOLD
Pair of Depo front fog lights BNIB £50
Pair of used gen :mitsi: front fog lights c/w mounting surround etc. £60
Carbon slam/ cooling panel £SOLD
Carbon engine cover, Rexpeed, OEM style £SOLD
Carbon wing vents (new) Rexpeed £SOLD
Carbon brake cooling ducts c/w mounting brackets (new) Rexpeed £110
AYC service/ bleed tool £90
South Side Performance (SSP) bumper mounting catch tank and pipes. Texas race series £160
MAP REV3 Inlet manifold with ceramic heat coating £SOLD
Standard boot spoiler Phantom Black £SOLD
CBRD BBX full turbo, fully overhauled and unused since £900
CBRD tubular TS exhaust manifold with heat coating £SOLD
Genuine Bride seat on Bride X specific sub frame (drivers side) £380
Evo X steering wheel, re-trimmed in Alcantara with blue, unused. £SOLD
Whiteline adjustable anti roll bar set, front and rear
Whiteline adjustable rear bottom arms £SOLD (will split see thread with pics HERE )
Forge BoV £SOLD see thread HERE Will also fit earlier cars.
Transfer box, fully rebuilt, upgraded, ISF polished and cryogenic treated by CliveW, unused since £SOLD
5 MT gearbox, fully rebuilt, upgraded, ISF polished and cryogenic treated by CliveW, unused since £SOLD
Owen Developments MHI billet turbo with ceramic ball bearing and metal cage core upgrade and shaft speed sensor ready. (Completed one track day and mapping time only) Always mapped with the speed sensor so kept with recommended limits. Covered approx 220 miles £1525 (Speed sensor equipment available)
MAP Investment cast exhaust manifold with ceramic heat coating £490
MoTeC M800 ecu with datalogging, advanced functions and knock control upgrades. Knock control board added £SOLD
(MoTeC C125 race dash, expander and sensors available separately)
Contact by PM or post up on here
Email [email protected]
41 - 58 of 58 Posts
Bride seat still available? Do you know the model and size?
Yes, it's a "Low Max"
Don't know what you'd want me to measure for the size :confused:
How much for the front pair of Bilsteins with Eibach springs?
When I said I'd split them I meant the springs from the struts. I'd rather sell 4 struts and/ or 4 springs
Sorry if I've confused you :smthumbup
You've confused me too. I asked weeks ago if they were still available and you said they had just sold?
Thankfully my knocking noise wasn't the suspension. It was an engine mount bolt so I didn't actually need them anyway :)
Sorry, it was the Ohlins that'd sold, anyway I saved you some money so all's good! :smthumbup :D
No worries :smthumbup How much for the set then, with springs?
£210, I can get some pictures tonight if needs be.
Would be glad to see how they look, please. Are they in fully working order?
They were working fine when they came off a couple of years ago, Actually they are Tein springs
You could have at least given them a bit if a clean up:eek:
Sent you a PM
Kev :smthumbup
Still have evo 10 wheels with tyres
Hi, do you have any photos of the AYC bleed box and do you have the gauge and blanking bolts that come with it?
Thanks.
Thanks.
It’s just the box, no gauge or blanks etc, that’s how it came. No idea how to post pictures on here nowadays, it’s completely changed since my time!!!
id imagine the gauge etc are relatively common parts?
Just seen that you can buy the gauge etc separately for about £55 + postage
41 - 58 of 58 Posts
