All prices are collected from Leeds, West Yorkshire. Make me an offer.
Block cradle
Flywheel
Standard short engine, used but good
Complete head with cams, Mivec pulleys, some pipes and thermostat housing etc
Trigger wheel, front pulley, starter motor, cam cover, timing chain case
Oil pump, alternator, power steering and air con pumps, sump, various pipes and brackets
Standard exhaust manifold, standard turbo
In theory most of the parts, above, to build a complete engine with some ancillaries etc. Ideally sell as a job lot £1850, will entertain parts if enough interest.
Long engine, complete with most outer parts, suit a rebuild project (crate engine) £1800
Used Cosworth parts, crank, ISF polished and cryogenic treated, complete ported cylinder head, con. rods and camshafts £SOLD
Cosworth fuel injector rail £SOLD
ETS 4" bar core intercooler £SOLD
Koyo radiator (water) KV032037R £140
Carbon propshaft (suit GSR, not RS) £SOLD
Complete set Ohlins DFV c/w top mounts etc £SOLD
Complete set standard used Bilstein suspension with Tein lowering springs (will separate)
Pair Exe-tc adjustable top mounts (front) £50
Ross Sport swirl tank c/w Bosch 044 fuel pump etc (good for 600bhp) £220
Set of 4 ID 1000 fuel injectors £SOLD
3" air inlet pipe c/w maf housing and cone air filter £SOLD
AP Racing brake set front and rear (discs cryogenic treated) with XP10 pads, 2 spare front discs and 1 new disc (cryogenic treated) £SOLD
Full Milltek de-cat. exhaust with 5" slash cut outlets £SOLD
Powerflex 10Z75 front wishbone front bushes BNIB £12
Blox roll stopper BNIB £50
Mishimoto additional oil cooler (MMOC-EVO-08) BNIB £SOLD
Timing chain (Mitsubishi MN183896) cryogenic treated BNIB
Oil chain (Mitsubishi 1140A073) cryogenic treated BNIB £SOLD (for the pair)
K-MAC full race adjustable camber mountings BNIB £180
HKS Super Hybrid air filter BNIB £SOLD
Pair of Depo front fog lights BNIB £50
Pair of used gen :mitsi: front fog lights c/w mounting surround etc. £60
Carbon slam/ cooling panel £SOLD
Carbon engine cover, Rexpeed, OEM style £SOLD
Carbon wing vents (new) Rexpeed £SOLD
Carbon brake cooling ducts c/w mounting brackets (new) Rexpeed £110
AYC service/ bleed tool £90
South Side Performance (SSP) bumper mounting catch tank and pipes. Texas race series £160
MAP REV3 Inlet manifold with ceramic heat coating £SOLD
Standard boot spoiler Phantom Black £SOLD
CBRD BBX full turbo, fully overhauled and unused since £900
CBRD tubular TS exhaust manifold with heat coating £SOLD
Genuine Bride seat on Bride X specific sub frame (drivers side) £380
Evo X steering wheel, re-trimmed in Alcantara with blue, unused. £SOLD
Whiteline adjustable anti roll bar set, front and rear
Whiteline adjustable rear bottom arms £SOLD (will split see thread with pics HERE )
Forge BoV £SOLD see thread HERE Will also fit earlier cars.
Transfer box, fully rebuilt, upgraded, ISF polished and cryogenic treated by CliveW, unused since £SOLD
5 MT gearbox, fully rebuilt, upgraded, ISF polished and cryogenic treated by CliveW, unused since £SOLD
Owen Developments MHI billet turbo with ceramic ball bearing and metal cage core upgrade and shaft speed sensor ready. (Completed one track day and mapping time only) Always mapped with the speed sensor so kept with recommended limits. Covered approx 220 miles £1525 (Speed sensor equipment available)
MAP Investment cast exhaust manifold with ceramic heat coating £490
MoTeC M800 ecu with datalogging, advanced functions and knock control upgrades. Knock control board added £SOLD
(MoTeC C125 race dash, expander and sensors available separately)
Contact by PM or post up on here
Email [email protected]
Block cradle
Flywheel
