1 - 9 of 9 Posts
Discussion Starter #1
after fitting a stainless manifold to my e8 what happens to the stainless pipe that bolts to it ,as it will not fit back on the new manifold.........the pipe in question bolts on in 2 places and is about 14mm diameter
did you notice much change in power with your new bunch of bananas....manifold????
im thinking of this mod??
Discussion Starter #7
MANIFOLD+ELBOW
BIG INPROVEMENT SPOOL UP INSTANT,MID +TOP END SEEMS TO PULL A LOT HARDER ,WELL PLEASED FOR THE OUTLAY.........WILL POST PIC WHEN I SORT OUT THE CAMERA
evo400 said:
the egr system needs disconnecting . blank the pipe work off.
Can you just blank the egr off after fitting a manifold, is there no implications??, putting a manifold on mine shortly
1 - 9 of 9 Posts
