do you have experince of them?And? if you have had interaction with them then why the comment. Nowt wrong with a sleeved block.
I cant answer that as I dont rally nor have I ever setup a car for rallying... hopefully somone knows though:lol: Do group N rally cars have to keep stock rods???What, in the current stage of developement, is the maximum torque a 4B11T can safely produce at 3500(ish) rev/min?
Assume a turbo capable of 3.5barA and FIA "turbo" fuel
Grant
In theory yesDo group N rally cars have to keep stock rods???
^^^^^ 100% agreePersonally, "if" I was running a 4B11t I wouldnt risk the engine being completely destroyed trying to squeeze large amounts of power out of it on standard parts knowing at some point it will let go. Its not "if" more "when". I would rather spend a couple of ÂŁK on rods, pistons, valves and springs than a couple of ÂŁK just replacing the 4B11t with another standard 4B11t unit when it lets go. Its a no brainer, peace of mind and strength for the upgrades.
Its worse than bear baiting:crackup:Gum, I dont see how the 4B11t can be such a great engine... granted the head design in terms of flow seems to be more advanced than the 4G63 but you would expect this as its a newer engine design. Pity all the other flaws are letting it down, the block is weaker (than 4G63) and requires sleeves, the rods are not holding up too well even on standard un modified cars, piston ring lands failing due to ring gapa and a few cars with dropped valves.
It looks like you have to take the 4B11t and create a new engine from it using aftermarket parts![]()
Not at all.Its worse than bear baiting:crackup:
Few, too, seems speculative and unqualified
Evidence of the standard, non modified, no bolt on failures please
And are 4g63's not known to throw rods below 400bhp?
Again you say the engine has a flaw
Its design includes an alloy block that requires sleeving, how is that a flaw?
Sorry i took this to be your opinion:I didnt say it had a flaw, the link was to a thread that says that
But now you mention it,
do you not consider rods through the side of the block a flaw?
or piston ring lands failing due to incorrect gap clearances a flaw?
or valves dropping a flaw?
The block needs resleeving to run big powerIs that not a flaw in the standard sleeves then?
Does the 4G63 or 4G64 block need sleeves to run big power?
and yes.... I have experience of a sleeved block and it wasnt a good one :wallbang:
If you fly to close to the sun, you're going to get burned..simples.Pity all the other flaws are letting it down
4g63 is far from flawless with standard internals at 400/400 mate!! Just think how fat the X would be with a 4G in there :lol:Not at all.
Try the search button on here and evoM for your answers.
Thats the point i was trying to make that they are completely different engines and need different methods. Its not purely down to tuners in my book, manufacturers of aftermarket parts have a lot to answer for as well. Anyone that has seen dyno graphs of various mods on a standard (unmapped) X will tell you the same. Some parts on a standard car are verging on dangerous, others actually smooth out some issues with the car in standard setup. Like others have said its a totally new development, and it will take time to gain a similar level of knowledge that exists for the 4g63's. That won't be gained by scaremongering or running anything down.It appears to many 4G mappers are now trying to map the 4B the same way. To many EVO-X have completed endurance events to see this event from TTP validated in any way. Same idea with other issues with the
4B ,is having people cry wolf. Better engineers will get the 4B working. People around the globe like AMS,Magnus, TMR etc whom have great engineers will work it out before to long.
Don't think the 4B is not up to scratch! Just try harder!
:thumbup:
yeah, they could all change the oil ring?It appears to many 4G mappers are now trying to map the 4B the same way. To many EVO-X have completed endurance events to see this event from TTP validated in any way. Same idea with other issues with the
:thumbup:
you work for who?Its always the same with new products, people live in a blame culture and they will contaminate as a cover for lack of engineering talent and mechanical understanding. Good engineers will quickly make the EVO-X smooth reliable and dangerously powerful. A couple of key people(talented engineers)around the globe have already developed EVO X products that I am sure you will see add to the mix. I like to think as a DR! Before I surmise ,I like to inspect and be curious about how things are made.
As I said before, Just try harder!
No you dont... its simple in my opinion:It looks like you have to take the 4B11t and create a new engine from it using aftermarket parts![]()
