Guest
·I had installed the Magnex cat back system so I thought that the next logical step would be to de-cat it. When I replaced the gaskets either side of the de-cat pipe I noticed that the internal bore of the gasket (2 3/4 ) did not match up to the bore of the de-cat pipe (3 ). I phoned Magnex and Ralliart to see if there was a larger gasket available but no luck, I have also been to a few auto-factors but they only have 2 3/4 and cannot help.
I know that there are a lot of people using these exhausts so could you tell me what gaskets to use and hopefully where do I get them from? If it was just a small difference in size then I would not bother but when you look down the de-cat pipe there is quite a step.
Regards.
Dean
Regards.
Dean
