58.36, 0.04s away.
One run to go
One run to go
Thanks, Not bad times from yourself tooWell done Donald,, get back soon..![]()
Thanks, Not bad times from yourself too. I'll be back next year hopefully.
Kenny, I had a quick look at the data logs and i'm only using 80% throttle most of the time to keep the boost sensible and away from the cut threshold.
To explain the situation, the engine was overboosting all weekend with no obvious reasons why the boost aim would have changed. We were seeing 3.5bar.
She needs to go back onto the dyno to be setup again as I've applied an overall trim of 70% and she's still making 3.1bar :wallbang:
Frustrating as i've had a few boost issues this year and it's affected the performance at every event so far. Most of the time it's been too low boost.
I'll get some vids up later in the day![]()
Will do. Am going to check wastegate diaphragms tonight too as that's about the only reason I can think of for the changes we're seeingEmail me the logs if you like. Rick is on holiday but i can take a look through it this afternoon and give you a call.
Possibly. That 58.32s record of the Banana is a quick time, I had to drive Tiddles hard to get into the 58's let alone a low 58I think you would have been in the 57s had it not been for your problems Donald.
If only :lol:Well done Donald, if you can bottle any of that extra boost up I'll buy it no problem :smthumbup
Tony
I watched your run and heard the boost multiple boost cuts. I'm surprised you even got a 61 with it running like that.Possibly. That 58.32s record of the Banana is a quick time, I had to drive Tiddles hard to get into the 58's let alone a low 58
That's pretty close on sectors. My logs ECU show I hardly used full throttle as I didn't want to be damaging my engine and most of the time i never went above 80% throttle. I still had boost cut.Great time Donald, good effort!
Looking at your sector times on the 58.36 run, you went quicker then me off the line, and then through the esses section to the blind left, although i suspect that may well be due to the zero lag response of your car coming out of the essess.
3C 124 Donald McCaskil 2.02 7.93 12.62 12.48 13.82 9.49 58.36
3C 147 Steven Darley 2.03 7.89 12.78 12.46 13.80 9.36 58.32
Couldnt be any closer! I will have to try find some Avons, and see if i can push it into the 57's like my sectors suggest is possible!
Look forward to the videos.
Yes, the speed trap is part way up the hill, and you can hit higher, having hit 112 before lifting for quarry. I have done 108 through speed trap and only just made the corner.I watched your run and heard the boost multiple boost cuts. I'm surprised you even got a 61 with it running like that.
I saw you do a 95 terminal, but I've seen mr Darley do at least 103 up there. I'm sure he said he was doing over 110 at the top. Steven?
Looked a handful on boost :smthumbupThat's pretty close on sectors. My logs ECU show I hardly used full throttle as I didn't want to be damaging my engine and most of the time i never went above 80% throttle. I still had boost cut.
Here's the in-car video of my T2 run from Sunday. I forgot to press 'record' on the line of my 58.36s run
I can be seen turning the boost down just before the entry to the Esses. Didn't make much difference though
Boost cut is set at 2.8bar in the ECU but the system still makes boost during the boost-cut itself as it builds boost so quickly. After 2.8bar there is no more power, just a tell-tale in the logs of the system reaching 3.5barYes, the speed trap is part way up the hill, and you can hit higher, having hit 112 before lifting for quarry. I have done 108 through speed trap and only just made the corner.
Perhaps the acceleration whilst overboosting was making up for the boost cut!We run 2.5 bar up there, although i think i tried a bit more when i ran the 42.
112 is mental. that's 17mph quicker than Donald's car looking at the video he poster. crackers. how did you make the corner? :lol:Yes, the speed trap is part way up the hill, and you can hit higher, having hit 112 before lifting for quarry. I have done 108 through speed trap and only just made the corner.
