1 - 10 of 10 Posts
Discussion Starter #1
Mr 340 decatted, run in and tanned now......
Under heavy acceleration all is fine, back off in a highish gear and i get a loud BBBMMMM noise coupled with a resonating rumble from the centre of the Hooge exhaust....
Sounds like its trying to flame, but i kind of delays for what must be a milli second ones ability to plant the foot down again.....
Anyone else got simliar sounds or effects like this
Jas. the born again hoon!!
Discussion Starter #3
So what the hell is it i wonder...... Sounds interesting to me. I havent seen you around the Mid Northants play area yet... I keep looking havent seen many at all apart from a grey one on the A14 at Kettering, and a grey one going into the Kosovan Car Sanding (washing) place on the A1 near Southoe.
Maybe someone can find the answer...... :coolsm:
do you have blow of mate?
i had same problem with mine, but also my engine didn`t keep revs like should.
engine was getting too much air.
since i removed mine everything is perfect, and engine is smoother than before.
hope this helps
if it does it at high revs in say 4th or 5th, then you put your foot down, nothing happens, then it goes, then its the secondary air system and is normal.
Jason,
I have seen you about, at least I think it was you. On the A45 heading into Northampton about 3 weeks ago.
Hope to see you about soon.
Happy motoring. :D
Chris
Discussion Starter #8
Hi Chris it may have been me my man, was on economy drive mode or balls out???
Hope to catch up with you soon mate.
When we do ill introduce you to my brother and we can laugh together at his WR1
Jas.
By the way lads the only blow off i know off :crackup: Occurs in my pants.
The car sounds mad when it makes the strange rumblin, and its when you quickly back off, it kind of just hesitates for a few milli seconds, and barfs as it does so.
:moon:
1 - 10 of 10 Posts
