Lowest uk drenth dog gearbox prices!
M.E.Rallysport is pleased to offer the lowest UK Drenth Dog Engagement Gearbox prices.
Evo 4-9 Drenth dog box gearkit £4150
Evo 4-9 Drenth sequential conversion build kit £3950 (This is required on top of above base kit to achieve full sequential)
Evo 4-9 Gear Change kit £425
Upgrade to flat shift lever £350
Closed loop flat shift ecu loom and gear display £495
Labour to build from donor 5-Speed Gearbox £400
Uprated x tube £200
Gear display and loom £325 (For use if not fitting closed loop system)
Al prices plus VAT and Delvery
As used in Worldwide Rally, Time Attack, Sprint and Hillclimb Disciplines
Best Regards
Matt
For the record, I have used the Drenth Dog box kit in my Evo 9 for the last 2 years coupled up to an Ikeya shifter with flat shift and I've not so much as put a dog ring in the gearbox in this period. With regular oil changes the box can be kept in great order for very litte money after the intial outlay.
Discussion Starter · #4 · (Edited)
Hi Jon,
For the full sequential you need the standard dog engagement gearkit and the sequential conversion kit, which is the total of the above items at £8100. Its then your choice on how you make up the kit to the spec you would lke, I.E flat shift or not etc. We will need your 5spd box to build the kit into.
HTH
Matt
