1 - 14 of 14 Posts
Laptop upgrade
Current laptop seems a bit slow, thought I might upgrade memory
TOSHIBA SATALITE S2410-703
PS241E-7PTKK-EN
SAMSUNG
KOREA 0319
Currently 2-off PC2100S-25330-A0
M470L3224DT0-CB0
256MB DDR PC2100 CL2.5
RUNNING WINDOWS XP HOME
ANY ADVISE WELCOME
Memory / 1GB PC266 DDR SODIMM CL25
From Kingston Via PC world £ 70.77 each
If I installed 2 gig
Would it work or is there a limit on what my laptop would support
Would it be quicker
Word of warning you can only put 512 in each slot
Each memory slot can hold DDR PC2700 with a maximum of 512MB per slot.*
*Not to exceed manufacturer supported memory.
To see the memory installed in your computer click the Scan My System button below.
Number of Slots:
Slot 1 Slot 2
Thanks Fozzy, thats one of the first sites I found, what happens if I exceed 512 MB per slot?
Fatman said:
Number of Slots:
Slot 1 Slot 2
There would be good chance your computer wont fire up after its fitted, two slots of 512 should be plenty for a laptop, what are you using it for?
Work
Autocad
Excell
ETC
But multiple applications paging file sometimes under heavy use
53 processes
I guess want you really need is a dual core cpu with plenty of memory, im sure 1gig should see a big difference when running applications though.
1 - 14 of 14 Posts
