1 - 20 of 20 Posts
Has anyone bought V3 coilovers but with adjustable top mounts from Kw how much are they for a vi:handsup:
Formerly known as DazK-IV
Have a chat with AC Speedtech mate. They are are a KW Suspensions Performance Partner.
http://www.gtr.co.uk/forum/487633-acspeedtech-now-kw-suspensions-performance-partner.html
They supplied & installed my "hybrid" V3 coilovers onto my GTR and set it all up very well (so well that a professional racing driver actually commented on them very positively so I fully recommend it / them - obviously on a GTR but I imagine that an Evo set-up will be of equal quality).
So going to be the same as club sport but don't want to run that heavy spring rate on the road and £2600:goingmad:
My "Hybrid" V3s run Club Sport springs but that works out better for a heavy car like the GTR. For an Evo, I would think that the standard V3 springs will work fine :smthumbup
Are you :goingmad:at the spring rates or the price?
Yes don't want track spring rates as the B roads around here are not that smooth as have Tein at the moment which get tied in knots but are ok on smooth roads. I want adj top mount not rubber with camber adjustment.:smthumbup
Phil
I think you should talk direct to KW. I've have some pretty good contacts who know about KW suspension and the key point being made to me about the V3 is that it's clearly intended as a road damper and therefore only suited for use in conjunction with standard top mounts.
It may be worth exploring other avenues if cost is a factor. The Meister GT1's are getting favourable reviews and the pricing makes them very attractive.
We have KW on all our cars and they make a setup for all purposes, message me your requirements and we can work out the best solution for you :)
THANKS FOR A QUICK AND FAST DELIVERY OF MY KW CLUBSPORTS
HAVE TO SAY THERE LOOK AND FEEL TOP QUALITY OVER THE OHLINS I HAD
...AND THANKS FOR BEING THE UK'S CHEAPEST AGENT........:smthumbup
just bought some kw clubsports from ant :smthumbup
what settings are you using for fast road
Mine are set up for competition use as that's what the car is used for mainly. :)
They come with a set up sheet and its usually pretty close to the use you tell them the car is to be used for.
Do you know what spring rates your KW Clubsports come with?
Sent from my iPad using Tapatalk
Discussion Starter · #19 ·
Get some pictures up so we can all have a drool:smthumbup
1 - 20 of 20 Posts
