1 - 5 of 5 Posts
Just got the 8pot 330 kit for the front and having a few problems with clearance of the rotors on the lower arm. Has anybody else had this problem? Don't really fancy having to use shims or grind the arms.
Has anybody upgraded the rear brakes using Ksport kit? Got the 6 pots again with 330 rotors but no handbrake which is a bit of an issue!! has anyone gone down this route before?
There is a problem with the III, Andy Fox can confirm in more detail.
The discs do foul the lower arm which can be a bit scary if turning. Andy had to modify his lower arms and we replaced the rotors as it scored them.
There is a thread IIRC
I think he also sorted the rears/handbrake.
As above AndyF had problems with this, seems kit isnt a very good fit on early cars :( also rear kit as you say means you have no handbrake so not ideal on a road car, you would need to pipe in a hydraulic handbrake system which means more piping, not worth the hassle imo.
Ian
yes all early kits are same the bell offset isnt right and need casting marks taken off the bottom ball joint
1 - 5 of 5 Posts
