Hey everyone does an Ali Koyo Radiator fit straight in an E5/6 ? i heard there may be fan issues ? gotta collect from Post Office tomoz am so cant check size yet. Any other issues or problems i may encounter fitting it ?
Hi Mate,
Direct fit pal :)
The fan shroud is only tight when using a larger turbo or a bigger inlet. However, I use a 4 inch inlet on mine with the filter at the front and have managed to shoe horn the whole lot in with my Koyo Rad.
If you are on standard turbo and pipework or even 3" inlet you will have no issues.
Use a piece of card on the back of the rad whilst fitting the fan etc so you dont bugger the fins up.
regards,
Stevie
