1 - 8 of 8 Posts
Hi folks
I have some annoying knocks when I go over small bumps or uneven road surfaces. It doesn't seem to do it when I hit big holes or bumps but its particularly bad in my street as the surface is very lumpy. THeres no noise when I turn lock to lock or bounce the suspension. If I had to stick my neck out I'd say it seems to come predominantly from the front right but my mate can hear some from the rear too (when he's in the passenger seat).
My first thoughts where bushes but after searching the archives I'm not convinced. Does anyone have an idea what I should do or have any little tips or tricks to pinpoint the problem please?
Thnx
Daz
Thanks guys, I dont suppose you know how I can tell which of those two it is? Anything I can do that would narraow it down?
Out of interest, how much did it set you back to get the top mounts and struts done m8?
thnx again
Daz
top mounts £50 each (approx) struts £100 each (approx) Then plus labour to fit. Shouldnt be a big job if you go to a specialist. Mitsubishi wanted £300 just to fit the struts. They were fitted in a couple of hours by CPP. Both these parts are common problems with knocking. Get it checked out by someone who knows these cars or you could end up fitting parts that are not needed.
ive developed a knocking from the driver side tonight after taking a left sharp corner at 85,its only wen i turn left and drive over bumps in the road,i can feel the knocking through the go fast pedal,done a search and seem to get loadsa answers like this thread for example,so did anyone have the same problem as me and get it sorted first time?
top mounts?
droplinks?
struts? (only had these ones on a year)
1 - 8 of 8 Posts
