Anyone got any info on this?
http://www.pistonheads.com/classifi...-9-in-stunning-ruri-blue-low-mileage/6986146#
The mileage is a bit higher than I'm looking for but it's close to me and in my preferred colour. The MOT history was fine up to 2015. I don't know much about the mechanics side of a car so does anyone know if these advisories are that bad and if you know how much it will take to sort. I know about the tyres and brakes issue fine and oil leak one isn't good but looks like is has been sorted since it doesn't show up on the next mot.
Also has anyone ever heard of Wallace Performance as I can't seem to find their site? Just so I know if they are good or not.
MOT history of this vehicle
Test date: 1 July 2016
Expiry date: 10 July 2017
Test Result: Pass
Odometer reading: 57,759 miles
MOT test number: 7858 4570 4558
Advisory notice item(s):
Nearside Rear Macpherson strut has slight movement at the upper attachment (2.5.A.1c)
Offside Rear Macpherson strut has slight movement at the upper attachment (2.5.A.1c)
Offside Rear Inner Suspension arm has slight play in a pin/bush (2.4.G.2)
Rear brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
Test date: 10 July 2015
Expiry date: 10 July 2016
Test Result: Pass
Odometer reading: 52,741 miles
MOT test number: 2673 7139 5115
Nearside Front constant velocity joint gaiter deteriorated, but preventing the ingress of dirt (2.5.C.1a)
Nearside Rear Tyre worn close to the legal limit (4.1.E.1)
Offside Rear Tyre worn close to the legal limit (4.1.E.1)
Oil leak
from https://www.check-mot.service.gov.uk/
Thanks in advance
