hi i have recently bought an evo4 which makes a crunch changing in to 5th from 4th at high revs .I have been told that it is probably the syncros that need to be replaced .Can anyone tell me if a evo7 gearbox be a straight swop as i can purchase one cheap in good condition cheers neil.
does any one no the gear ratios between the evo 4 and 7 gear boxes.Will i lose top end speed or be quicker of the line or are the ratios so close to gether will i not notice the differance thanks neil
gear
i had one in a 5,iirc it was a slightly higher speed for given rpm-but as said not that you would notice
