Guest
·Light,
roughly what is the relationship between flowrate and intercooler exit temp?
The inlet temperture will be almost constant for a fixed inlet manifold boost pressure. If the heat transfer coefficients were constant then there would be a inverse linear relationship beween flowrate and temp drop - as flowrate doubles so temp drop halves.
However coefficients will change. According to Perry the heat transfer coefficient of finned surfaces is proportional to velocity to the power of 0.6 (equation 10-64). Velocity is proportional to flow.
I think this means that intercooler temp drop is proportional to flow to the power of -0.4 or as flow rate doubles the temp drop will be ~76% of what is was.
Hmmmm may have just answered my own question. Any comments?
Of course the transfer coefficient of the metal will not change with changing flow but this is normally massive anyway.
