· Registered
Which is the best way to go?
I have read that the apexi power intake is the best for filteration, but I am also aware of the hot air problems associated with induction kits.
So which is best, and before anyone complains, searching didn't find any comparisons between the two. Opinions please. :D
· Registered
You could build a custom made cooler box around whatever filtration system you employ to lower heat soak. Carbon fibre appears to be the flavour of the month these days - bear in mind that you need to design it so the air intake feed is compatible with it. :)
Or just get yourself a Blitz Sonic with the metal shroud (used to reduce heat soak).
