errr...depends if you want to keep doing handbrake turns on the road or not I suppose. I know I don't, I like to look after my diffs thanks :)
I saw my friend's evo do a clean 180deg handbrake turn with a hydraulic handbrake at really low speed, and I thought it was cool. And u know how wide the evo's turning radius is ... might be useful sometimes to do a u-turn instead of a 3-point turn, heheh :D
Well off course you don't need that if you don't use it to turn, but if you do it is better than the normal one.
BTW, I did not really get the point ie of the evo vii that will release the acd when you use the hand brake for turns.
With my V rs, when I use the handbrake, I press the clutch pedal, so what will be the exact difference?
Hydraulic handbrakes are illegal for the road, you will not pass an MOT. You must maintain a mechanical rear brake for the handbrake, not a hydraulic one.
