NOW SOLD
For sale is my 1/10 HPI Maverick Strada MT Evo "S".. Brushless., i no longer need this due to running a Savage, and dont use it, only had it around 4 weeks with the intention of bashing it but as its so nice i didn't want to wreck it. it is as clean as you can see by the pics, the bottom scuff plate still has the original sticker on it, so you can see its not got lots of scuffs.
If you decide you like the looks or have read reviews on these you will know that there is a range of Maverick verity and this being the "S" of he MT trucks is a great RC. comes with everything pictured and also includes instructions. this is RTR out of the box.
A professionally designed moulded tub chassis provide durability and provides a stable and tough platform for a strong 4WD shaft drive-train.
Pre-built oil-filled shock absorbers and fully independent double wishbone suspension give you supreme confidence on all surfaces.
The pre-installed electronics now include a 2.4GHz RC system along with a super powerful brushless motor and long life battery pack for plenty of fun!
Features:
Fully assembled and Ready-To-Run
Pre finished body shell in new color scheme
22BL 3215KV Brushless Motor
80AMP Brushless FWD/Brake/Reverse ESC
ESC Compatible with 7.4v LiPo batteries & has built in LiPo Cut-off
3000mAh Ni-MH battery with Maverick high current connector fitted
Mains 400mah trickle charger with adapter lead included
High-strength steering servo
2.4GHz RC system with built-in fail-safe
Large titanium anodized motor heat-sink
Molded tub chassis with optimized weight distribution
Fully adjustable racing suspension
Battery strap will accept both stick packs and side-by-side cells
8 oil-filled rebuildable shocks with progressive springs
Special titanium anodized shock tops
Fully independent double A-arm wishbone suspension
Tough C-hub front steering knuckles
Tough efficient 4wd shaft drive train
Fully ballraced drive train
Aluminum titanium lightweight center shaft
4 large all-terrain block pin tires
Attractive 6-slot wheels
Fully adjustable turnbuckles all round
Front and rear molded bumpers
Twin-point steering with integrated servo saver
Molded protective gear cover
£140 Delivered
Here is a link to ebay..
http://www.ebay.co.uk/itm/161218232195?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
PM or Email - [email protected]
Frankie
:smthumbup
