Hi my evo 7 is playing up and wanting adviceAs above is there any way of telling if the AYC is working or not on E6,7 and 8?
I beleive a light appears on the dash on the 8, not sure about 6 and 7 models?
Any help would be much appreciated.
Cheers.
Is there a code reader that works on evo’s mate?Have you tried pulling the codes?
(I am getting intermittently the 3 lights on & believe it is an ABS sensor.)
Yeah cheers mate got code 22 and code 26 speed sensor and absHave you tried pulling the codes?
You can use Evoscan (with an OpenPort cable) or bridge pins 1 & 9 of the OBD port. The code will flash out on the CEL (slow flashes for 10's rapid flashes for 1's)Is there a code reader that works on evo’s mate?
At least it isn't 82 - AYC codeYeah cheers mate got code 22 and code 26 speed sensor and abs
Cheers mate, Where can you get evoscan?You can use Evoscan (with an OpenPort cable) or bridge pins 1 & 9 of the OBD port. The code will flash out on the CEL (slow flashes for 10's rapid flashes for 1's)
