> A 50/50 AWD car from an a 50/50 AWD can differ greatly as a
> differential is not the only factor to a car behaviour, many other
> aspects of a car come into action
I'm talking in the context of the thread so we're talking factory spec evos, not ones with altered suspension, ARBs etc.
> and yes a 50/50 AWD car can and will either oversteer or understeer
How is it going to oversteer? What are the physics behind that?
> The reason mitsubishi created the AYC/ACD system as these too were
> developed to work together and not independently
AYC was developed first independently of ACD, and some cars have ACD but not AYC.
> AYC is stopping at the best degree possible the tail of the car to
> slide out
Why is the tail going to slide out? You keep saying these things as if they are true and when questioned you give no explanations behind your arguments. When you accelerate through a corner the longitudinal forces on the wheels are roughly the same front and rear, except the weight transfer gives the rears more traction and the fronts less. As well as having less traction than the rear the front tyres have greater lateral forces being applied to them due to the steering angle. As the speed increases and these forces increase, why are the rears going to break traction before the fronts when the fronts have less traction available and more forces acting upon them? On a rear wheel drive car, greater acceleration puts more force on the rears allowing them to overload before the fronts so break traction before the fronts, but on an AWD EVO greater acceleration loads the fronts as well as the rears so the rears are not going to have more load than the fronts. The fronts are always going to have greater forces acting on them mid turn so will always give first....so.....I ask you....again...explain the problem you think AYC is trying to solve, and also explain why giving *more* torque to the outer-rear wheel is going to result in reducing oversteer when oversteer happens when there is too much force being applied to the wheel?
> as for the mid turn comment of yours in which you actually admit that
> an open diff offers no benefit in traction, thus the main aid,
> differential wise, to you to keep the car planted on the road is the
> AYC, but to further enhance traction and to help the AYC, mitsi
> changed that to an LS diff on the MR model
The MR still has ACD so still runs an open centre diff in the same situations surely, as do the RS models (post-ACD ones obviously). I didn't say an open centre diff offers no benefit mid-corner, it does. Your belief that my statement that the diff is open mid corner was somehow a negative shows your general lack of understanding when it comes to diffs and vehicle dynamics. When I said the diff was open that was not a criticism, when your tyres have traction you want an open centre diff mid turn to allow the front and rear wheels to do what they need to do unhindered as they travel different distances and need to travel at different speeds. This is why the pinnacle of Mitsubishi's driving technology gives you exactly that. It is also why that mode is labelled "tarmac"...ie for when you have good traction. Mechanical centre diffs give benefits in some situations and drawbacks in others, the active centre diff of ACD is designed to give you the best of all worlds. Why do you think WRC cars used active diffs? Why do you think they were banned for being too effective?
You are saying that an open centre diff mid turn is bad and that a non-open centre diff gives more traction mid turn so maybe you can explain why that is? In tarmac mode it is assumed you have good traction so the centre diff opens to allow your front and rear tyres to act independently to best get your car around the corner. Whilst great on dry tarmac, if you are on a loose surface or a slippery surface like wet tarmac\snow where there is a chance that low traction *will* make the tyres slide then your open diff has gone from being a strength to a liability as the sliding tyres get the torque and you lose drive. So in gravel and snow modes an amount of locking and limited slip remain (to varying degrees) so that if your tyres do lose traction mid-turn then the tyres that have the traction (probably the rears for the reasons I've explained above) still have power they can use and torque is better distributed in general. Good for slippery conditions, but bad for dry tarmac as the locking in the centre can hinder cornering when traction is good. This is the great thing about electronically controlled diffs...the best circumstances in a range of situations, especially as in tarmac mode the locking can still come back in as you are exiting the bend where a little throttle\understeer is more likely.
You however stated that ACD needs throttle mid corner and I've asked you to explain why and you have not yet answered that question yet you continue to repeat the claim so can you explain the reasons? You have also stated about that a non-open centre diff gives more traction mid corner. I've given a very basic explanation of why I think not above, so could you please respond in kind and give technical explanations and reasons behind what you're saying?
> No the only one here saying things that are not as such in reality is
> you, showing that you have very little knowledge of what and how the
> system works.
I'm backing everything I say up with explanations, all you have is statements you claim are true (despite some being factually inaccurate) and offer no explanation and refuse to answer any technical questions put to you. On the face of things it seems that those are the actions of one who has no real knowledge but have just misinterpreted what others have (sometimes erroneously) said and is regurgitating them as being true without knowing why.
