just changed myuturbo to a bigger 16g thats ported etc and now suffering with real bad boost creep at 10 psi itl creep to 17 buy 7 000 rpm got a greddy profecbspec 2 controler etc wots best wayt to sort it..
he has a brand new actuator with the brand new turbo ;)
best bet is to go to the nz mmc forum and do a search
late evo dont suffer as bad with this soon as you fit a large exhaust turbo back the turbo produces more air flow than the wastegate can get rid off so the higher the rpm the higher the boost rises as wastegate port cant flow eoungh ;)
god its too early for this :rolleyes:
Just fitted a new turbo housing ,that i got from mach v a contact that ian supplied for me. The housung was a fairly straight forward fit and has a huge 38 mm wastegate. Now its all fitted along with a dawes device i can report that i have no creep at all and runs a very steady boost it peaks to about 1.3 bar and then holds a steady 1.2 bar and can go a bit more but im playing safe.
Carl
