As above guys had Stoptech discs with XP10 pads for over a year now. Just returned from a very successful ring trip and on the last day during a session on the GP circuit a started to experience judder through the brakes when braking from high speed. I am just assuming this is deposits from the pad left on the disc. How can i get rid of this?
Any more suggestions?
Stick a set of rc5+ pads on, the judder will dissapear after roughly 10 times of braking hard. A bit noisey but the performance far outweighs that trait.
Normally I would say fit a decent pad like xp10's :lol:
I'd try doing some very hard braking and get the brakes red hot, then drive around a bit avoiding braking allowing it all to cool. I didnt think xp10's were prone to pad deposits though, so maybe another issue causing the judder
Stu
Sounds stange, first thing I would be doing is a brake service getting pads out and checking everything is working/floating as it should be, we see a lot of brembos now where pads are binding due to lack of service/corrosion etc and this causes judder issues due to pad temps going through the roof as they cant release from disc.
Ian
Thanks for all the replies, my calipers were refurbished by Godspeed in August last year front and rears. I run XP8 rear pads.
I am going to remove the discs and pads to see if there are any immediate issues that i can see. Get an airline on the caliper and clear out all the dust then go again and see if this helps.
