I know this topic has been discussed before, but can anyone confirm that to remove the front bumper, all you have to do is undo the four bolts (two each side) that attach it to the chassis rails, plus the bolts and screws in the wheel arches? Are there any other bolts/screws that need to be removed?
Yep the four main fixings are uynder the car - from memory there are some others you have to take-out too - top of bonnet cathc panel and clips to under arches, but once youve freed the four main ones the others become obvious
Don't forget the intercooler pipe at the bottom of the pump and fog light connections if you have any. I had to do this a couple of weeks ago to replace my wrecked intercooler.
I didn't need to jack the car up to gain access to anything, the only problem I had was finding a socket set with enough length for the four bolts.
Good Luck.
