1 - 3 of 3 Posts
Anyone know how to adjust front wheels camber on evo6??
I didn't see any eccentric bolt on front to do this unlike rear strut....
Thanks for reply!
I think that you can adjust the camber with one of the two bolts that fix the shock absorber at the bottom.
One of them should have an arrow on it,and if the arrow is in one direction the camber will be approximately 1.0,and if you turn it on the opposite direction it will be 2.0.
There was some other topics about this,you should try to use the search engine.
You can also fit the hks pillowball top mounts,but they are about 200£ for the front and 150£ for the rear,with them you can adjust the camber from the top mount.
With gr.n or fast road supension kit usally the camber is adjustable.
Spot on Maxi thats totally correct,my dealer did not know this I had to tell him and amp;gt;
1 - 3 of 3 Posts
