Best way here.
They run upinside the chassis legs as fas as i knowgareth_evo5 said:Have you removed the invisible ones??
There are 4 fixing bolts in the chassis either side of the engine, get under the car, looking up, behind the spot light, further up, there is the chassis beems running north/south (under the battery on the 1 side) there are 2x14mm head bolts each side. Have you removed these?
G.
