1 - 5 of 5 Posts
got a e6 gsr running with full super drager exhaust and hks filter plus hks blow off valve just fitted a boost gauge and the boost is peaking at just under 1.4 bar am i right in thinking this is a tad to high never had fuel cut or any other probs Turbo.........
Factory boost setting is 0.9-1.1 bar , so if yer gettin' 1.4 u must have done something else , I wasn't getting more than factory boost with a much less restrictive custom Blitz system with PE down pipe.
I cannot see you running that high if your still using the standard boost controller situated under the black cylinder.(nearside innerwing in the engine compartment).
You sure it`s not modified?
Rich.
Had a look at boost controler looks original to me and the so talked about gromet is still in there all pipes and things look in a 1 con so still dont know what is cause to boost so high
1 - 5 of 5 Posts
