I have an evo 4 and i would like to know how much bhp you think it will have with the mod i have put on. (1) 1000bhp intercooler (2) evo7 turbo (3) A full de-cat system (4) And a high flow manifold. (5) a induction kit.:lol:
fuel cut and crank walk probably:smthumbupI have an evo 4 and i would like to know how much bhp you think it will have with the mod i have put on. (1) 1000bhp intercooler (2) evo7 turbo (3) A full de-cat system (4) And a high flow manifold. (5) a induction kit.:lol:
What bhp do you get out of your e6 block?need to sort out that engine dudewould defo get a new fuel pump, bigger injectors and even then the 4 engine is paps at that sorta power. and talking from experience. now running a 6 engine in my 4. good luck tho to be honest without a remap it wont be much more power than standard.
fuel pump cause the one fitted is probably getting lazy (with age), standard injectors will be fine, boost controllers are good to keep it smooth and running standardish boost. get the afr checked on the rollers and dont be to hard on it and it might be ok. the 4 engine doesnt like being worked to much over standardNo she goes nices thanks.im going to put it on a rolling road. i was thinking about 300bhp
the induction kit alone will screw the mixture.....fuel pump cause the one fitted is probably getting lazy (with age), standard injectors will be fine, boost controllers are good to keep it smooth and running standardish boost. get the afr checked on the rollers and dont be to hard on it and it might be ok. the 4 engine doesnt like being worked to much over standard![]()
ran many evos with filter and exhaust, 4, 5, 2 x7s, 9gt and if you keep the boost real it shouldnt be a problem. evos run rich from the factory.the induction kit alone will screw the mixture.....
ok, i learn something everyday:smthumbuptotally needed on my 260.
was fine before apexi - post apexi fitting, ran well rich and only 180 odd at wheels =- 236 approx atf which is WAY down.
was running so rich the zorst was black.
added the zorst, first run, even less bhp on dyno, about 175.
remapped and she ran 275atw (362 approx atf w/ 24%)![]()
no worries though you are right, stock they run a tadge rich anywayok, i learn something everyday:smthumbup
yep didnt think of that charlieremember though guys hes on a 4 ecu so will need a ecu swap aswell as a remap
was thinking that but wasnt 100% sure so kept stoom:blush:remember though guys hes on a 4 ecu so will need a ecu swap aswell as a remap
