fitting a hks turbo timer as any one fitted one of these i need to know where to connect the remaing three wires blue grey and amp; brown i know one goes to the hand break but not sure which one dont have a clue where the other two go also anybody got any english instructions any help very welcome many thanks DAZ
why are you not using a wiring harness?
contact justin (yellow5) tell him model of timer and amp; your car.
they only cost 8 quid (ish)
simple plug and amp; play no wiring to do
It sounds like you have the Type 1, correct?
If so, gray connects to the handbrake. You should get a harness from Justin at torqueic.com, this will make the other wires easier to hook up, directly underneath the steering colum, one easy connection.
I know the blue/brown wires tap into your computer. One taps into the RPM signal lead wire (brown), the other goes to the Speed signal lead wire (blue). To tell you the truth, I wouldn't connect these two wires. The other stuff that the timer offers really sucks, it doesn't measure things correctly, especially RPM. Just connect the gray wire, and use the harness for the other wires. thats all you really need..
