Guest
·Just joined the BBS and I'm interested to know how some of you guys manage to run more than around 1.2Bar boost pressure without hitting fuel cut and/or running lean.
With my current situation, I cannot see any other way but to replace the ECU. Is that how you've all gone about it?
Initially, I fitted an HKS FCD. This device scales the MAP signal to the ECU thus having the effect of shifting fuel-cut higher up the scale, albeit at the expense of leaning out the mixture (hit 16.3 at WOT.. which did give me rather a scary moment!). This lean condition was compensated by fitting a higher pressure fuel-pump that brought the A/R down to around the 10 mark. So by further increasing the division ratio of the HKS FCD, the mixture was leaned out to a more respectable 12.0 at WOT.
Okay, I admit all that sounds like a bit of a cludge but I'm just learning about the car and I like to start things slowly and experiment; take things stage by stage, all that kind of thing.
There was also some problem with the boost curve, which turned out to be a faulty wastegate actuator. The seal had perished around the actuator rod, which meant most of the pressure was escaping down the side of the rod. When the actuator pod was cut open, it was *very* rusty inside. I figured that, over time, water had corroded the rod at the base and wrecked the seal.
A new actuator pod was sourced from Turbo Technics. The old pod was cut from the stock bracket and the new one bolted on. This also gave the opportunity of fitting a pod with a lower actuation pressure, so as to make it faster acting and to give the opportunity of running lower boost when just cruising along motorways and the like.
Next mod was to fit the new Blitz boost controller (together with the HKS FMIC which was the subject of a post I made to another thread). The Blitz unit sits rather nicely under the head unit and I especially like the 1/4 DIN format. Found a great space for the underbonnet black-box at the front of the LH chassis-leg (just ahead of the battery tray). This location is a relatively cool area yet is still quite close to the turbo, so pipe-length could be kept to a minimum.
To set the Blitz controller, you have a range from zero to 100 where a setting of zero is stock boost and 100 is wastegate always shut. I found that a setting of 60 equals a boost pressure of 1.11 Bar or 16 psig. If I turn it up further, however, around 1.2 Bar I hit fuel-cut.
There is still room for a further increase in the division ratio of the HKS FCD *but* this will have the effect of leaning out the mixture - which I obviously cannot do. So that's why I'm stuck in a rut and the only way forward seems to me to be fitment of an aftermarket ECU. Unless there is some other way.
Thoughts anyone?
Yours,
J
Yours,
J
Thoughts anyone?
Yours,
J
Yours,
J
