1 - 9 of 9 Posts
There is also an option to remove the recently moved docs section in start menu properties somewhere, am sure you can do it without editing the registry but if you want to do that and can't find it I can find the reg key you need.
Super Moderator
Jesus built my car
Depends on your OS.
Right click the Start button and select Properties. That should bring up "Taskbar and start menu properties". On the first tab click "Customize" and there is a "Clear" button to remove recent docs. If you don't have the "classic" menu you will need to select the Advanced tab to see the Clear button.
Aidy said:
Depends on your OS.
Aidy you stop this Helping people Malarcy, its just not you!!
Your supposed to slate him for not knowing **** about computers!!
Edit your post please!!
RINGREY said:
Cheers gents but too late!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Uh Oh the missus has found the "Lesbian Vampire Cheerleaders flicking the old goats testicles" Movie hasn't she? :mockery:
1 - 9 of 9 Posts
